Had a quick look around the site and can't seem to find the answer I was looking for. Hopefully I have parked this in the correct forum.
The 1st - 2nd lever on my M21 transmission came loose last night and while I was able to fix it to get home I thought that it should be torqued and perhaps a dab of locktite to keep it from coming loose again.
Does anyone have the correct torque setting for the levers on an M21 and should I be using a dab of blue locktite or maybe red
Thanks guys
http://www.dansmc.com/torque_chart.htm
Here is a torque chart using bolt grade to help with size. You can use a smaller
length wrench so not to over torque by hand. You did not say weather it was a
bolt or nut that held the lever on. I would not use any thread loc on the
bolt/nut un less there is something wrong with the threads.
Dave
67 Nova Boy
Here is a torque chart using bolt grade to help with size. You can use a smaller length wrench so not to over torque by hand. You did not say weather it was a bolt or nut that held the lever on. I would not use any thread loc on the bolt/nut un less there is something wrong with the threads.
Dave
67 Nova Boy
Dave
Good information thanks. I will put it to good use.
Threads are good and actually its a bolt (not a nut) with a plain washer that had loosened off.
Roger
had the same problem with mine last year :yes: Lock washers took care of that problem :D
