This will be the combo soon, im still ordering all the parts, lemme know what you guys think,suggestions, assumptions on power/torque
ENGINE 1996 LT1 from camaro
Heads: Trick Flow LT1 aluminum, 2.02 1.60ss valves, beehive springs
195cc 68cc 72cc 3/8 arp rocker stud
comp pro magnum 1.6 self-aligning rockers,pushrods,lifters
Intake:GM LT1 carbureter conversion, aluminum dual plane
Fuel: Holley 750 vacuum, all choke accessories were removed
Ignition: converted from optispark to HEI, MSD cap,rotor,wires, pertronix flame
thrower coil, module, comp gear
BottomEnd: all forged 383ci scat rotating assembly
Timing chain: comp magnum double roller
Camshaft: comp cams "xfi" hydraulic roller 292/300 advised duration
584/579 lift, 113 lsa, designed for beehive springs
Cooling: northern aluminum radiator,16" electric fan w/aluminum
shroud, CSR electric water pump, 160 thermostat
Balancing: internal balanced, with new Proffessional product balancer
Exhaust: "dougs" 1 3/4- 3" ceramic headers, 2.5" pipe, custom "flowmaster"
style mufflers
TRANNY
TH350 stock case,fully built internals, 850$ worth
"BTE" 10" 3500-3800 stall converter
REAREND
stock (for now) 8.5 10-bolt with spool, 3.90 gears
no subframe connectors, or traction bars yet, im goin to install a rear coil over kit and get rid of the springs eventually, so tell me what ya think guys
style mufflers
TRANNY
REAREND
