LSx engine install with 1966 stock frontend - require the stock crossmember removal?
I have a 1966 Chevy II with the stock front end and a CPP front subframe suspension kit with the sway bar. It used to have an I-6 engine and powerglide transmission. I now have an LSx engine and 4L60E transmission to install. I have an LS2 2004 GTO oil pan. I have the LSx engine seperated from the transmission for ease of motion.
I have been working by myself in the garage tonight and have not been able to lower the engine into place. It will get close but then the oil pan hits the black stock crossmember (see the red arrows in the picture below). It looks like the engine would need to slide back about 1 to 1 1/2 inches to clear this crossmember.
The CPP subframe suspension plate (light blue color) at the front end looks to provide rigidity and support and with the engine bolted to the motor mounts would help hold the front frame rails in place.
My ideas after tonight....
1. Is to remove the screws and drop the crossmember and swaybar till the engine is in?
2. Locate a 1 or 2 inch piece of metal stock and make a spacer to drop the crossmember lower to support the swaybar?
3. Or can \ should this crossmember and swaybar be removed altogether?
The crossmember looks to provide support for the CPP swaybar and the brake lines are mounted off the side towards the firewall. I can replace the brake lines if neceessary to re-route them out of the way.
I'm open to suggestions or ideas if you've worked through this issue please speak freely.....
Thanks for your time, Brad
Note: The rust in the picture below is surface rust. The car is in better condition than what this picture shows. I plan to detail and paint under hood before the engine install is finalized. I got a Nikon 12 Mega Pixel camera with auto-focus that catches small details (rust) very well...
