1 - 19 of 19 Posts
I'm about to put a Gen III 6.0L/4L80e in my 62 nova.
I have the heidt's front clip installed.
Just wanted some in put from someone who has done it.
I plan to use the S&P mounts.
Anyone one that has done a LS1 conversion please let me know:
What mounts did you use?
What headers?
Type of transmission? Crossmember used? Shift used?
Wiring harness used?
I have read plenty of posts of people putting this setup in 1st Gen Camaro, but very few people using 1st Gen nova.
Any help greatly appreciated
I saw something mentioned over at LS1Tech.com. You might wanna check that out...
Hey,
Check out the Street and Performance site. They sell a kit to install an LS1 into a first gen.
Todd
Ls1 swap
I swapped a 2002 ls1 into my 66 nova. Used a jimease chassis front clip (complete piece of junk). S&p motor mount plates the s&p slave cylinder adapter plate they sell for the f-body worked great. I had to run a 7" brake booster from SSBC. Headers are hooker block hugger stainless (fit great). I used the t56 so I called phil at BRP hotrods (770-751-0687) and he built me a crossmember for $165. He also makes one for the 4l80e. My car is not on the road yet but this summer it should be rollin.
Discussion Starter · #6 ·
Thanks for all the info everyone.
I have been to LS1tech.com and S&P's sites lot of good info at both places.
I would like more first hand knowledge from someone that did the swap.
Anyone else?
With my Heidts' sub frame I had to have the passenger side engine mount cut and rewelded for the needed offset and to fit the S&P motor mounts. The F oil pan fits OK. The A/C compressor had to notch the mounting bracket a little then it fits right in. Stock drivers side exhaust fits, passenger side doesn't. I modified the passenger side unit to fit(fun!?) as I've yet to find a set of headers other than the block huggers that fit. right now I'm looking into the new Hooker (https://www.holley.com/2288-1HKR.asp) header and the Stainless Works (http://www.stainlessworks.net/cart/product_info.php?cPath=94_225_226&products_id=1178) one. Check with Year One for the trans mount (http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=6). Hope this helps some.
Discussion Starter · #8 ·
Thanks.
Great info Pete...
I was wondering if the camaro pan would clear.
That's good to know.
Motor and tranny get here tomorrow.
Looks like I need to find a LS1 pan ASAP.
Also let me know about the hooker headers if you try them.
Thanks...
Stock coils are supposed to be good for like 2000+hp, kinda makes the $800. MSD coils kinda pointless...lol.
1 - 19 of 19 Posts
