1 - 16 of 16 Posts
anyone have any experience with the GM Performance "muscle car pan"????
looks like it gives more clearance than the F body pan:yes: and it's $149 new:yes:
You do not want the muscle car pan. I have already been down that road. It hangs too low and it hits the rack.
Let me do a search of my thread and I'll get you pics of both pans installed.
Do you have the front or rear sway bar? If it's the rear I believe you will need to change to the front mount. Or saw up and weld a pan.:bored:
Camaro pan! Fit's great on my late-2010 TCI front clip. Did they move the sway bars on newer ones?
Tci
You have a OLD TCI clip YOU HAVE TO MOVE THE BAR to the front mount or you will never fit the F-body pan here a pictures of how close it fits.
I know i have a PT clip but i have a IFS it fit the same way i am guess the MII is also the same.
1963 Nova coupe, Phoenix Arizona
You need the front mount sway bar, and the F-body pan fits great. I had the same problem,mine had the rear sway bar. I had had my clip for a year or so before I installed the motor,and realized the sway bar wouldn't work in the rear.So I called TCI to see what they could do, to my surprise they said no problem we'll swap it out for free. They sent the new one, and said put the old one in the same box and return it,they even payed for all the shipping:yes:
I don't think you can ask for better customer service than that.
Discussion Starter · #14 ·
I'll try calling them on Monday and see what happens, I've had my clip for a while :(
If you wanna get hardcore, TCI told me the Milidon roadrace oil pan will work as well. It's what i'm using on my swap. My motor isn't here yet, so i can't comment on the fit yet sorry. I have the new PT clip with front swaybar.
Edit, Milodon 31507 will fit.
http://www.summitracing.com/parts/MIL-31507/
You'll have about 1/4" clearance between the bottom of the pan at the front and the power steering rack.
Using TCI LS1 conversion mounts. Sorry i don't have CBR mounts to try out. So i'm not sure on them.
6.0L LS2 alloy block.
TCI Torque Arm rear clip
TCI Transmission crossmember
Kelpro MT8008 transmission mount (don't know what this is in an american part no. sorry)
All my measurements have around 1/4" to 1/2" clearance
Block to top of crossmember is 3"
Bellhousing to back of crossmember is 12"
Block to bottom of crossmember is 5 1/4"
Block to power steering rack lines is around 1 7/8" NO EXTRA CLEARANCE HERE. You might squeeze in 2".
Front of block to back of rack is 3"
Width betweeen lower suspension arms is 20"
Front of block to swaybar is 2 1/2"
I used the stock pan that was on the 98 Camaro motor and tranny I put in my 63 wagon. I used a TCI front end and stainless works headers and church boys mounts. I had about i/2 inch in front and across the top of the crossmember.
1 - 16 of 16 Posts
