Im doing a LQ4 swap into a 63 and wanted to use the Muncie 4 Speed thats in the car for now. Outside of a better clutch what all else is needed to bring these to together?
Why can’t he use the factory peddle setup..?I think this will be the BH you will be needing...
https://www.holley.com/products/drivetrain/bellhousings/bellhousings/chevrolet/parts/RM-6036
I would also look into swapping it over to a Hyd Throw out bearing set up. Trying to fish headers around a Z bar would probably be a PITA. Look at American Drivetrain for a conversion clutch pedal kit.
Im sure he can. I would think it would be easier to fish a -3 Teflon hose down past some headers vs a Z bar.Why can’t he use the factory peddle setup..?
I’m totally on board with going to a hydraulic operating system. I just thought you were starting that the stock clutch peddle would need to be changed for some reason.. Hands down, I prefer a hydraulic operated clutch system..Im sure he can. I would think it would be easier to fish a -3 Teflon hose down past some headers vs a Z bar.![]()
lots of guys use stock pedal set up with a hydraulic release bearing . Stock pedals have absolutely no bearing on using a z bar or a hydraulic release bearing
- The LS engines don't have a provision for the Z-bar pivot, so he'd need to fabricate one.
- Off the shelf aftermarket headers and manifolds would likely interfere with the Z-bar, linkage, and throwout arm. That could mean a lot of purchasing & returning to find the right fit, or head-scratching if he builds his his own.
- It's a lot easier to tweak a hydraulic setup if the pedal force or amount of throwout travel winds up being too much or too little; simply change the master cylinder vs reworking linkage arm ratios.
Assuming his headers wouldn't interfere with the throwout arm, he could potentially use an external slave cylinder. That would eliminate potential headaches that arise should the slave cylinder start leaking (which a quality one shouldn't).
My question was merely in regards to the factory clutch peddle only not any of the subsequent mechanical Z bar mumbo jumbo..
Yes, it does.lots of guys use stock pedal set up with a hydraulic release bearing . Stock pedals have absolutely no bearing on using a z bar or a hydraulic release bearing
