i dont rub it all on the roads, i have long tube headers and they dont scrap at all!!! my frame is low, if i jack it up i need to either lift it from the fron of the frame rail of back towards the end of the frame rail..no biggy for me
the car feals real connected on the road, absolutely smooth, i dont carve corners but if i hit a bump i dont get taken for a spin..
my back spacing now is 4" with ( from the tire) atleast another 1/2 to go before it would hit the outer tie rod..i can take pics if you guys like..
the superior kit is the way to go, im not sure of any spindle man. that allows more back spacing then superior, ive had cpp, mc caughys. these are the best, for the 3 rd gen..ive been helping nvrdun71 he had some questions..since he wasnt sure about his tire size ( front) he ordered the qa1 system for the front, which gives a little more fine tunning and just in case a little more room for hieght adjusment
every car is different, like i said i had small amount of rubbing in the front only on the left outer sideonly at full turn but not on the right side..now someone else it maybe different it seams ever car is different..did some tweaking and i dont have any more problems
the rear is hotchkis 1.5" lowered spring. i run a 275/40 and i ( with the old grinded lips trick) have more room for a bigger tire atleast a 295
