I want to get some slapper bars and use lowering blocks to lower my car two inches. I just realized that the two might not work together. With the lowering blocks spacing the bottom of the spring pad away from the spring, won't there be a lot of space between the slapper bar snubber and the leaf spring?
Also what do you recommend for some traction bars? I don't need super duper ones since I only have a six cylinder and I don't drag race it. I just need something to stop wheelhop. Do the traction bars replace the lower spring mounting plate or bolt on underneath it?
I found some Lakewood traction bars for $99 at Jegs. These look any good?
http://www.jegs.com/webapp/wcs/stor...goryId=13131&parentCategoryId=10083&langId=-1
-Aaron
-Aaron
