Needing the vac for power brake booster? I had one of those before it worked good for one pedal push. I changed to hydrobooster,no more worries. Or get a vac pump for the booster with limit switches for on and off.
Wow 5lbs! Thats a lot!Well the brakes work, I just know it could be better. I'm seeing about 5LB's at idle in gear.
Hydrobooster? Details?
the last thing I want is a noisy pump!
Here is a link for some reading. It uses powersteering pump to multiply pedal pressure.Well the brakes work, I just know it could be better. I'm seeing about 5LB's at idle in gear.
Wow 5lbs! Thats a lot!JK'ing
I have the same problem 8in of vac at idle. Will prolly get a pump from older chevy celb.
All is well and good until that panic stop to keep from hitting something with your "PRECIOUS"...12Hg is a minimum must....Get the pump for sure:yes::yes:....JackWell the brakes work, I just know it could be better. I'm seeing about 5LB's at idle in gear. !
