1 - 20 of 36 Posts
I'm wanting to do something different with my fuel cap... Give me some ideas, pictures etc.
I love those things. One will probably be making its way to my car before its done.
Some guys graft fuel doors over a recessed filler cap. Looks great IF you use the right shape of door.
Yeah since my car is being repainted I might as well change gas cap to fit the look of the pro touring theme.
Look at my post from earlier today Power. I got a great deal on mine and put a link there also.
1963warwagon2
Power, it really depends on the genre of your '67, i.e. prostreet, gasser, cruiser, restored etc.
The gas cap assembly you listed would look good on say a prostreet car, but would look not so good on a cruiser or gasser.
My opinion in a case like this is less is more.
Hagan Auto Smooth Gas Doors
This is their example of the round flat, but they have oval, square, teardrop, rectangular etc available and they all seem to be about $135.00 each.
These have been used in the street rod cars for years and look great. They are available for all sorts of curved or flat surfaces. These would look good on just about any genre of Nova.
Just my 2¢.
Good luck with your choice.
This is a Eddie Motorsports one, dosen't have a lock. I think they have a new one now for the 1st & 2nd Gen's. I had to put a spacer behind mine to flush it out.
Rebob
What did you use for a spacer, did you make one or buy one?
Travis:D
Travis
I basically made a big aluminum washer ,3/8 or 1/4 thick,I don't remember,to put between the cap and the body.
Rick
Yeah thats what I was kinda thinkin too, did you grind the lip flat on the original body/filler neck area? or leave it?
Travis
I cut the entire end off the filler tube that the cap goes on and used rubber gas tank hose to connect the new cap to the filler tube. I also added a weld on bung to the top of the filler tube so I could install a fitting for a 3/8" vent line.
I meant on the body itself, did you do any mods on that area?
Travis
1 - 20 of 36 Posts
