Hello to all, Ive been a long time reader-of-the-post, but this is my first post. First off, this is the best Nova site.
I have a 70 Nova SS original 396 from LA. Low Miles. Did a complete intertior resto(carpet, gauges, etc etc) A complete drivetrain build (build 12 bolt, TCI th400, TCI stall, and the motor) All suspension components replaced, etc (I will get pics up sooner or later)
OK, current motor is a 70's 454, cast oval heads, Edelbrock intake, Demon 850, hooker heads, MSD Distributor, 6AL box, timing control, etc.
I pulled the motor last year when I bought it, painted the block, did an oil pump, Milodon 7qt pan, and a few other things, ran mint for the summer and fall. Good Oil pressure and didnt have any problems. Got it going for the spring, while driving it, noticed oil pressure starting to get lower and lower (may have been the sending unit for the gauge, but prob not) I decided before anything got severe to pull the motor and tear it down. Tore is all apart, found gasket material in the pick up and the pump. Noticed the Cam lobes to look kinda discolored (Hydralic Flat) and a broken valve spring. I decided to go with a Comp Cam Hydralic Roller set up (11-430-8), new pump, and have the block and head tanked. Measured the crank and rod journals, nearly identical to stock specs (never machined)
I ordered a new set of Crank,Rod, and Cam bearings(stock replacements) Ive thought about it and doing a lot of reading here and online, do I even need to replace the bearings? The crank do not have almost any signs of oil lose, nor do the con rod journals. The bearings have a very uniform color, almost all gray, stil have part numbers on the back side (prob done recent before I bought it) The crank itseft only have a very small about of "glazing" I guess you call it (looks kinda like a glazed rotor) I dont want to open a bag of worms by replacing them to a non machined crank. Budget is getting smaller and I dont know what to do? Polish it with emery cloth?
Thank you in advance
Rob
Rob
