What PW said.
I agree with Paul.Also note some cam companys will advertise their cam timing / duration at .020 , but the recomended valve lash will be .024:shh:
So you must calculate your ACTUAL running timing at .024
and factor this into your comparisons of other cams.
IMHO it's best to compare VALVE timing at a half a thou with running lash in.This is what the running engine see's.Lift rate and lift under the curve is another area to be considered,,but IMO the true valve timing is when the valve just sets down or just breaks it's seal.There's alot of performance lost or gained at lift's under .020.
WP
RED67:chev:
