Put lipstick on your dipstick. :devil:
OPEN YOU RE EYESWho uses a Lokar Transmission dipstick ??? I have one for my 350th. It is awful difficult to see where the trans fluid level is supposed to be.
Anyone else having this problem ???![]()
Ricky, we'll see what you are dealing with this weekend. I have a funnel i bought a long time ago that I use for tranny fluid. You can get them at most part stores for a couple dollars. its is a smaller size regular funnel and has a long, flexible straw connected to the bottom of it.Don't get me wrong, I like Lokar's 'stick. :yes:
It's just plan hard not to overfill. I have'nt seen any tiny fluid spouts to pour the fluid into.....![]()
Mine's plastic (nylon?) too...by the time you get it fished out so you can see it, the fluid just shrinks away and makes it hard to read. I'll have to try the scotchbrite trick, that sounds like a great idea.Ricky, I have a Lokar stick on my 700r4. It is plastic and I scuffed it some with a scotch-brite pad to take the shine off. That made it easier to read the fluid level.
Ricky, I have a Lokar stick on my 700r4. It is plastic and I scuffed it some with a scotch-brite pad to take the shine off. That made it easier to read the fluid level. It also came with a small adapter/funel that is used for fluid fill.
Frank
Ditto !!!!Mine's plastic (nylon?) too...by the time you get it fished out so you can see it, the fluid just shrinks away and makes it hard to read. I'll have to try the scotchbrite trick, that sounds like a great idea.
