Update: He said that he got the linkage adjusted properly, but the transmission will not stay in L1. He said there is a lot of play in the bottom of the column where the linkage connects that it is causing the column to move to the left when shifting. He said that the firewal seal is bad. Could this cause the play not allowing the trans to stay in L1?
Sorry for the noob questions. Not sure how to explain this all.
Any suggestions on how to change the seal? Do I need to remove the column and gear box to change it?
