im putting in a small block 350 4 bolt main
i have 350 heads with over size valves and been shaved down for more compression
the said the compression is 10:1 with pistons
i have flat top pistons bored 60 over
the cam is a performance 447 lift cam
and a summit hei performance distributor
with flow tech header with after burners
and bum 2300 stall torque converter
Edelbrock 4bbl Carb 750 cfm
Edelbrock performance rpm manifold
stock rockers for now
just wondering how much horse power will the motor have ???
other updates
right now the car is in parts. The front end is tore down .
No tranmission and no motor
took the ac and heater box off and going to replace it with the new heater box with no ac from Classic Industries. Going to redo the control arms with new bushings and ball joints. And then im going to sand the paint off and rust off the firewall and subframe and control arms and radiator suppprt and then paint them with black bedcoating i thought that would be cool looking.
I found a rusted hole around my windshied wiper motor wile takeing things off for sanding. should be and easy fix
and im going to add a brake booster
and redoind all new bushing for the front end
will post pic and more update just on dail up right now lol
forgot to say the motor is done just waiting on the carb and manifold to get here.
And i started sanding the car firewall and subframe and primed it yesterday just waithing on the black bedlining paint to get here.
going to try to do the control arms in the next week or two
other updates
