Hey folks 63 nova automatic powerglide shifter is on the column ? need the linkage not sure where to look i tried going to jegs edelbrok still no luck. Trying to keep original everything else is perfect but i cant find the pieces i need to connect the transmission help please im turning to forums now
from the looks of the pictures It looks like you have everything? laying there.
I agree with Larry ...... looks like (most of) the linkage is there, and should look like this :
#1
This is on my 69 250 chevy six ..... but should be similar as far as the "bell - crank linkage".
and, hooks to a 'pivot pin (or stud)' bolted onto your intake manifold. Then that small "rod" hanging on
your carb will hook onto the
"bell - crank"
#2 showing the pivot pin bolted in the manifold ... the bell-crank fits on (mine has a "C" clip -
to hold the bell-crank in place).
NOTE : your car (63) should use a rod on your gas pedal linkage (from the fire-wall to that bell-crank).
my 69 uses a "throttle cable" to the gas pedal to the bell-crank.
ENLARGE the # 1 picture ........ you can see the "Transmission kick - down rod -- from the bell-crank
down to the Powerglide tranny.
I hope this helps ............... " pictures ARE Golden" .
jim
------ and ------- WELCOME to SNS
glad to have you here
so ..... now your 1st picture shows up
but not the others ?
jim
