Just make darn sure everything is dry and clean as far as the gasket mating surfaces. Don't "bump" it with the jack - do all the lifting and lowering very smoothly, and it should be OK. I'd use at least a 2x6, maybe even a 2x8 if you can get one, in order to spread the load as much as you can.
