How much front end trsvel should one have on a 3rd gen? And what is the best way to measure it?
I just measured from the ground to my fender lip center axle. It was 25-1/4" at rest, then I jacked up the front end until the suspension stopped opening, and it was at 31" that was 5-3/4". I am not sure if that is the correct way to calculate it but that is what I did.
And what about the bump stops? I was told by some to cut them down to allow for more travel.
I have Moroso Trick Springs and Summit cheapo 3 position adjustables up front set at 90/10 and multi leafs w/Summit Cheapo 3 way adjustables in the rear set to 50/50 ( these things are a pain in the butt to adjust).
No one could tell me what springs they were using so I was researching the springs before the car was a runner to get it weighed.
And I found several old threads from years ago on some other sites and most of the guys that were testing and posting their results (BBC, SBC, Ford Mopar or whatever) concludes that the car always worked better with the next lighter spring than was was recommended by Moroso and/or their documentation (and the tech support guys were useless).
What can you all add to this?
Denis
Denis
