1 - 20 of 20 Posts
I’m sure it’s probably been discussed here, but I didn’t search through the posts. Is there an LED headlight that is a direct replacement for the ones in my ‘71? Ideally I’d like to be able to remove the stock headlight bulb and replace it with an LED. Is this even possible?
chewy . . . .
This is what I am going too use :
just more info . . . . . jim
ps : at this time , I am still using 'stock seal beams' .
I have changed all other lights too LED's , both front & rear lights .
I think my sealed beams are fine as far as brightness. I have no issues with the brightness. I just like the LED’s and figured as a bonus the amp draw would be less. Is the relay a necessity?
I would say (almost) . . . . yes , It DOES HELP - - - - Not required , but great up-grade . I had some wiring kits from work ( we were up-dating our lights on all of our equipment ; and, those lights had up-date wiring kits with relays , sockets , extra wiring).
So, that's what I used - - those 'relays & sockets' .
Classis Ind. also have "Relay Kits with wiring & soc.kets" . . . . look at this part number : MXO11232 .
There are several post (this has been a topic on here for years ; search : MADD Electric , they have kits & wiring diagrams) . I think it does help with both u'r (stock) wiring , and makes your headlights show brighter.
Here is another interesting read about using an " LED FLASHER " . This is the 2nd one I bought & it works
. . . . . (I made no adjustments, just plugged it in) …….. makes my LED front & rear lights "flash correctly" . They DID flash with the "NAPA # 262" flasher , but were slow too flash .
just info - - - that I have already found out . When, you find things that work good, that's what we want .
I hope this helps . . . . . jim
If you haven't pulled the trigger, look at Vintage Car Leds (7" LED Headlight Kits | 5.75" LED Headlight Kits | LED Headlights). I put these in my 63 and they are great. After I had them aligned by a shop I find them almost as good as a new car led light. About the best lighting addition I have made. One thing I really like about them is, unless you really look at them you probably won't notice they are not original seal beams
Discussion Starter #10
The octane lighting seems like it may be coming from China. Not 100% sure. The vintage car lights may be stocked state side. I am aware that they are probably both made in China. Anybody know?
you can contact member " Sreavis007 " he used those 'Octane Lights' in his 72 . Been a while . . . . . maybe he can give us an-up date ?
Discussion Starter #12
Yea, that would be great. Maybe he’ll chime in. I don’t have a problem with the Octane lights. They are definitely cheaper than the vintage cars brand. Not sure if that’s a reflection of the quality or not.
I kept my sealed beams but I did switch over to a relay system which improved the brightness a whole lot. There are several posts on here about that conversion. It's really not hard to do at. Since my car had already been converted to an internal voltage regulator I took that opportunity to find a used regulator in the junk yard, the old original style, not the newer flat ones, and I hid my 2 relays inside the box after gutting it and mounted it back in the factory spot. So, nobody sees the relays and my wiring system looks original to the casual observer.
I used truck lites in my nova, Harley and Jeep. I sell a lot of them to truckers, they love them. Maxxima and grote makes food lights too. These companies all manufacture lights for big rigs and are quality. I prefer truck lite as they do oem manufacturing and like the darker housings. The one on my Harley has been shaking for 5 years strong.
Street Rod HQ has an extensive choice and price is right. You can order with DRL's, turn signals and other options in your lights.
I got a pair of LED's from United Pacific. Throw great light and each has a horizontal bar across the center. On this bar you have a choice of white light for a daytime running light or an amber light for a turn signal. Plug and play installation. Only additional wiring needed is for the daytime running light or turn signal whichever you choose. I liked them so much on my '70 Nova that I installed a pair on my '37 Ford.
What is the LED flasher you use? Do you have a part number,etc.?
Hey Ghettoman . . . . . . . . . . yes . . I Do . Look here - - I bought it from Amazon like $ 12.00 & free shipping , a few years ago . You can see the " adjustment screw " on the
'Flasher ' - - - - - I Did - Not adjust anything - - - - just plugged it in about 3 years ago . Works great .
Look here :
I hope this helps - - - so far - - a really good product & price . . . . . . . . . later , jim
1 - 20 of 20 Posts
