Has anyone ever seen or heard of an intake manifold leaking? I was cleaning my intake(new to me, from ebay but very clean and in the box) and drying it off with compressed air. I was blowing out the carb stud holes and saw bubbling around the flange mounting surface, and noticed some little pits in the machined surface.
I spoke with several people and they said it should be fine. I just got the car running this afetrnoon and it sounded like it had a vacuum leak. It would idle crappy then great and so on. But with everything going on I didn't have time to look more into it, as I ran out of trans fluid after 7 quarts. I did a cam, head, trans and converter swap. Thought I had more.:no:
I got some more trans fluid and will look at it tomorrow after work.
of course you know your going to have to post video of your new monster. if your worried use some a & b epoxy to fix the problem. them engine master guys use it in the manifolds to fix turbulance problems and it should be fine with the chemicals ( gas , radiator fluid, water , oil )
Sounds like a factory "blem" sold as new on Ebay. Casting porosity can be fixed with epoxy or welding. There is a liquid sealer, that I read about somewhere, that requires making block off plates and pressurizing the manifold. The liquid is forced into the pores until it hardens.
I've had oil pooled up in the valley under the carb (Super Victor intake) after getting off the freeway--an hour later, it's gone! Can't see where it comes from or where it goes.
If you're worried about there being porosity in the intake and causing a small vacuum leak then I'd just get it powder coated. A Good heavy coating should be enough to effectively give it a "Seal Coat".
BUT......I'd also check the port alignment as well!!! If the intake is sitting a little too high then you can be sucking air from the lifter valley.:yes: That's the one major issue I have with buying a used intake is you never know who's had what surfaced or bolted down wrong and warped a flange.:rolleyes:
Discussion Starter · #7 ·
Thanks for the info and the link. I am going to go check it out and see whats up. I called Edelbrock and left a message with the warranty/claims dept but I haven't heard anything back as of yet.
Discussion Starter · #8 ·
I spoke with a guy from Edlebrock and he said if I can find the leak and then send him the manifold they will check it and if it is indeed a casting flaw they will replace the intake.
I have still not had a chance to check it out, but I'll keep ya posted.:yes:
