I just removed and reinstalled my motor for a leaking front seal and it's still leaking
. I installed the one-piece rubber gasket but had to cut out the large front seal section to install the smaller one...big mistake. I should have bought a new pan to accomodate the larger front seal.
Has anybody had a leaking problem that was solved with the one-piece rubber gasket with the large front seal?? I hope so because the thing looks friggin' leak proof.
In case anybody wonders, I checked to make sure I had good crank case ventilation to make sure I didn't have pressure building up...it was good.
