1969 Nova SS, 350, 4 speed, 12 bolt, A/C, P/B, P/S,
Hey guys, working on replacing leaf springs in my 69. On the passenger side the front bolt on the leaf bucket is loose and just spins but won't come out. Is there a bolt I can get to under the back seat or is there somewhere else I need to look? Hate to try and pull the rear seat if I don't need to. Thanks all....
1972 Nova
If you can get a thin screwdriver in from the bottom to hold things until you can unbolt it, I would do that. You might have to cut the bolt, as the j-clip that GM decided in their infinite wisdom to use has broken. I was welding up patches for my floor so I just cut that portion of the floor away, but if you're hesitant to pull the rear seat I'm guessing you don't want to go that route.
1973 2 door sedan 350 / 350
  • Like
Reactions: lg1969ss
Cutting the head off of the bolt is probably the simplest solution. But you could also modify (bend) a cheap wrench to slip in over the top to hold the nut, then replace all the hardware with the stuff that bowtieZone suggested above.
When you replace the hardware, though, make sure not to over-tighten the bolts. I know, they hold the rear suspension together, but they only need about 35 ft/lbs. of torque.
