I've seen radiator caps on some 1966 L79's located in the middle of the radiator and on others they were on the passenger side...Are both correct depending on whether they were built (U.S or Canada)
:confused
Not sure what you've seen, but generally a vertical flow radiator with tanks top and bottom, the cap will be in the center. On cross flow with the tanks on each side, the cap will be on the return side tank.I've seen radiator caps on some 1966 L79's located in the middle of the radiator and on others they were on the passenger side...Are both correct depending on whether they were built (U.S or Canada):confused
Thanks Bob,The center fill was the standard heavy duty rad that came on all L79s. The offset fill is the even bigger RPO V01 rad that was an extra cost option.
Bob
No, it wasn't specific to the L79. A lot of these rads got installed later in the life of the car.Thanks Bob,
I looked at a CDN documented L79 yesterday that had the offset fill. There was no mention on the docs or the build sheet of that option. Was the offset fill only available with the L79?
Martin
The owner would have had to change the rad support along with the radiator since the rad support had the indent for the cap in it. My guess is it was ordered with the car.No, it wasn't specific to the L79. A lot of these rads got installed later in the life of the car.
Bob
Martin, my L79 rad support had indents for both center fill and offset. Most others are similar.The owner would have had to change the rad support along with the radiator since the rad support had the indent for the cap in it. My guess is it was ordered with the car.
