You won't need much.
In addition to the V8 long block and transmission, you'll need everything else that goes on the engine ( intake, carb, air cleaner, covers/pan, distributor with related ignition parts, exhaust manifolds or headers, starter, flywheel, torque converter, alternator, fuel pump and lines, various engine brackets and pullies, etc. ), engine block mounts, V8 frame mounts, V8 throttle linkage, V8 radiator with related hoses, transmission cooler lines, TH350 style shifter linkage conversion parts or kit, V8 front springs, a new dual exhuast system, and probably a bunch of small various nickle and dime parts that I can't think of right now.
In other words, the conversion is easy. It just costs more money than you might anticipate not to mention you car will be "down" for a long period.
You might want to think about keeping the L6 and working on it. They can be made to make decent power plus they make your car stand out in a sea of typical V8s. Not to mention it would probably be cheaper to fix what you have. Also being able to drive the car as you work on it is a lot more fun than it sitting in the garrage for months or years. But if you have all the parts gathered and engine/trans fully assembled and ready to drop in, then the job can be done in a few days.
