1 - 19 of 19 Posts
Well I figured I might as well start a build thread. This will be going slow but it’s fun to work on. I’m going to be swapping in a 5.3(l33)/4l80e combo. I know I will need to cut the tunnel but we will see how much.
Today I got the engine cleaned up and switched over to an f body oil pan, pickup, and windage tray. Another member sent me some CBR plates to use for mockup. Thanks TomM!!!
I just need to get a shorter bolt for the recessed hole in the plate. With the energy suspension mounts, did everyone use the preload plates?
Here are some pics so far:
So far I rebuilt the stock upper control arms with Del a lum bushings. I am also running CPP 2”drop spindles, ls brakes, CBR lower control arms, sway bar, and power rack. Still using the stock column since I want to retain the column shift.
Making some progress. Got the old power train out, new motor mounts in and am prepping the new motor/trans to see how much I’ll need to cut the tunnel.
I thought the correct pan was the GTO 04-06? Or do you use the F body pan with the rack & pinion?
Miles
Discussion Starter · #6 ·
I believe you use the GTO pan with stock steering and the f body pan with the CBR rack
Discussion Starter · #7 ·
Made a little progress today. With a lot of wiggling and removing the top 2 bolts on the motor mounts, I was able to get the motor mounts over the frame mounts and slide the bolts through. After raising the back of the transmission, it looks like it hits in a couple of spots but a lot less than I thought it would.
Unfortunately, my angle finder is junk so I have a new one on the way!
Discussion Starter · #8 ·
Moving right along. I plotted it out and made some cuts and now I have plenty of clearance. It was less cutting than I thought it would be. I might open it up a little more to make the patch pieces easier to fit but not much. I have the driveline set at 3 degrees.
My crossmember kit should be here tomorrow so hopefully I can have this buttoned up this weekend!
Looks good so far! Also make sure to account for the cooler lines.
Miles
Discussion Starter · #10 ·
Miles
I’ve got banjo fittings for the lines. Should be no problem.
I finished up the crossmember and got it installed. Next I need to patch the floor and then then I should be in good shape.
Discussion Starter · #11 ·
I’ve got the tunnel just about finished. I taped a bunch of cardboard on top of the trans to give some clearance. It took lots of cardboard templates but wasn’t too bad. Just tedious. I had to add a little filler piece because I trimmed too much. Glad to be making progress. I will finish welding it in this week. Then I can pull the engine/trans back out for a transmission kit and converter from Jakes Performance, and a cam, springs, and pushrods for the motor.
Discussion Starter · #13 ·
I’ve got the floor finished up so I pulled the engine and transmission out. Unfortunately, I found out that the trans had gotten water in it. Didn’t find that out until after I opened it up. Time to look for a new core.
In the meantime, I swapped out the cam and springs!
I even got my special helper to help me out with checking the cam bearings! They look great.
I finally got around to modding the stock ac compressor bracket to fit around the CBR motor plates and motor mount. It only took about 20 min with an angle grinder, cutoff wheel and a flap disc. In hindsight I could have taken off a little less.
We will see how it fits once I drop the motor back in. The compressor will be tight to the inner fender but I’m hoping it fits.
Discussion Starter · #15 ·
Looking forward to see more of your work on this little Nova
I hit a little bit of a snag.i started rebuilding my 4l80e and found lots of water inside. Turned out the transmission was a total wash. I eventually found a “good” one and am in the process of rebuilding/modifying it now. I’ll make a post once I make a little progress
Discussion Starter · #17 ·
I found another core and am almost done with the rebuild. I’ll post some more pics soon!
Are you keeping the EFI with that cam or going to a carburetor set up?
Discussion Starter · #19 ·
I’m going with a Holley terminator max x setup for efi
1 - 19 of 19 Posts
