I have a 95 S-10 which has a OBD 2 style connector under the dash but if you read the label on the fan shroud under the hood it says "Certified OBD 1" , what gives? is it OBD 1 or 2? how can i check to see if theres any codes? i have a GM key for my 90 cavalier but i can't use on the 95 S10 because of trapoziod OBD 2 style connector under the dash. i tuned up the truck with new spark plugs,wires,cap & rotor, ignition coil, PCV, fuel filter, and air cleaner but it still runs rough between 1,000 RPM and like 1,500 RPM when im driving slow. it like misses or something. so when your going like 10-15 MPH you feel the truck rock a little because its rough at that rpm. but the engine light is not on. has anyone had this problem before? id apprecaite any help
thanks very much
thanks very much
