I run 28x11.50 ET Streets on 15x7s with 4.5" backspacing. Mine clear the fenders and inner wheelhousings fine. I used a 5/16" spacer on the driver's side to move the tire away a tad more from the shock (I wanted to see a little more clearance at the lower shock mount).71nova said:what size slick and rim do you guys recommend to fit under a stock wheel well?
Man, if I did that one time, that would more than likely be the last pass on that bottom end!71nova said:everytime i floored it off the line the tach would just shooot to 7k from it spinning so hard.
You're gonna have to just hold it with the foot brake and stay in the waterbox until you get some smoke, then drive it out of the box. The front brakes will hold you there while the tires spin. I noticed the rpm went to the moon, but the tires aren't getting any heat in them the way you're doing it now, and you might also be dragging water to the line. Try to start the burnout slower(not so much tire speed) so it doesn't fling as much water into your fenderwells, which then drips back down and.........i dont have a line lock but everytime i went in the water pit i would floor it and burnout until i got to the lights
