1 - 9 of 9 Posts
I installed a couple of interior lights in the wagon yesterday ,and ran into a situation .
after I completed the wiring and installed the lamps , they stayed illuminated :confused:
even when I disconnected them from the ground source , this made me think that wiring somewhere up in the roof or the light base , was grounding out against the body .
so I removed the pass side light base and the lights went off so I checked the terminals on the back of the light base to see if they were grounding out and it was not .
then I took a close look at the light base , at the area where the lamp terminals mount , and discovered that the chrome plating on the lamp base was making contact with the lamp terminal , and when I screwed the light base to the roof, the base was grounding out to the car and compleating the circuit
so I scraped the chrome plating away from around the lamp terminal area and it worked, now the lights operate normally
schwabie
here are the holes in which the lamp terminals install ( white area ) as you can see the chrome plating extends into the lamp terminal holes and actually makes contact with the lamp terminal when installed , scrape the plating away from around the terminal hole and it will not ground out when screwed to the roof
I turned the lights 90 deg. from stock placement and installed one on each side of the rag top
EXCELLENT info........:yes::thumbsup:
I had the same problem awhile back. In looking at an original dome lamp base, that area was free of plating., thus leading me to the same conclusion as you've discovered.
Craig, when I saw your thread title I thought...this must be a good (bad) one if a fellow electrician can't figure it out. Then I read your post..I should have known better that you had already figured it out. Good show, Watson. Excellent trouble shooting skills, as I expected bro. Lights look good too:cool:
:D:D:Dthank you ,thank you very much :thumbsup:
kemoschwabie
That schwabie is always thinking which explains why sometimes he seems to be in a world of his own. :yes: Well that explains it part of the time.:D:D
Discussion Starter #9
:yes::yes::yes::yes::yes:
yes sir I AM truly a space cadet :rolleyes: ...waaaaaay out there in outa space
like a super nova :D one bright moment then ,,,fizzzle out :sleep:
kemoschwabie
1 - 9 of 9 Posts
