Hello,
I have a question. Will a 1986 305 Aluminum intake fit on a 1961 283 engine without any problems?
Actually with a mild street cam the 2.02 heads work just fine (usually, check to make sure with light weight checking springs on one cylinder and a dial indicater. That will tell you how much lift you can run). With a small bore chamfer, they work freat with a big cam. I'd be more worried about your compression drop. If you have the 64cc heads your compression will drop below 8:1 unless you're running dome pistons. Yes the intake will bolt on and they're not bad intakes. They seem to be equal to an Edelbrock Performer.You cannot put a pair of 2.02 intake valve heads on a 283 because of the 283's small bore size, the valves will hit the cylinder walls/deck
