I soaked mine (same thing and same intake) with paint thinner. Took a few layers off then pressure washed it. Came out like new. If it's the spray can high temp stuff then this will work fine. Spray the paint thinner on it, let it sit and wrinkle, wire brush it, spray it again, and again and then pressure wash. Whatever is left just keep hitting it. You should be able to do the entire thing with about 2 small spray bottles of the stuff.
That or take it to get blasted, up to you.
i would go to NAPA and get a spray can of there gasket remover. then i would spray it on and let it sit for 10 mins and the just wash it . this gasket remover takes off paint for some reason. i use there gasket remover to strip paint myself for a while now.....
