1 - 15 of 15 Posts
Hey guys, I'm trying to decide what intake manifold would work the best for a new 383 I'm building. Currently I'm running an rpm air gap on my 355.
The specs:
383 ci, forged crank, rods, pistons, just shy of 11-1 cr, Comp cams solid flat tappet xs290s (.540", .558" lift, 252°, 260° @ .050"), RHS pro action 200cc heads (may be a tad too small), mostly strip but some street driving. Thanks for your help.
I'd stick with the Air Gap and test a couple diff spacers but that's just me.
I agree with Lug, especially since you already have it. I have the plain Performer RPM along with a 1" open hole wooden spacer on my 383. No track time yet though, hoping for some 11.30-11.50s.:yes:
I have a SR with a duration very close to yours @ 269. It's pretty lumpy in my 406.
It likes to idle around 1200.
Should be very interesting in a 383..
What converter,gears?
I have a big single w/ "1 open spacer,q-850 dp,"8 ATI treemaster,(currently 3.73's) and it flat out hauls!
Plenty of torque.
Besides the cam has the 4/7 swap..and I was advised that they like singles better.
Who knows.
Try the AG like was said. Ya got it.
Good luck.
I too have 3.73s but with a 4000 stall.
2975 Vic Jr. and at least a 1/2" spacer.
Cool. Thanks for the feedback!
If you have the hood clearance, I'd suggest the Holley 300-25.
Probably the most under rated manifold out there!
Just my 2cents.....:)
Jeff
Discussion Starter #10
Jeff
Shouldn't be a problem with my 4" cowl hood :D
I would say with a 4000 converter I would be more concerned with the actual USABLE power curve.
The cam most likely is gonna make power in the 3500-to-7000+ range. Throw in the converter and you're looking at a 4000-to-7000+ USABLE power range. Right where a single plane intake shines.
I personally like the Bowtie intake...
http://www.gmpartsdirect.com/performance_parts/store/catalog/Product.jhtmlPRODID=1007&CATID=995.html
Or for one of the latest favorites of a LOT of builders, look at the Edelbrock 2892 intake...
http://www.summitracing.com/parts/edl-2892/overview/make/chevrolet
Keep in mind that port matching the runners, properly blending them into the plenum maintaining a good amount of taper and working the plenum to even out the port entries could easily be worth 30+ extra HP!!! Just be prepared to see a LOT of metal on the bench and floor when you're done.:eek::devil:
Both the Holley 300-25 and 300-110 are two of the most underrated manifolds out there.
You better believe that!
I did a test, a direct real world test in my car.
The Dorton was on top!
:yes::yes::yes:
Al
1 - 15 of 15 Posts
