inline 6 cylinder head torque specs and sequence?
35K views 9 replies 4 participants last post by  short shift
Pattern
Torque spec is 95lbs.
I do 3 passes iIE: 30,60,95
NOTE: On a L6 engine the water jackets are open in block. they are famous for seeping water up around the head bolts.
Take a tap and clean the head bolt holes in block, clean the head bolts.
I use Permatex #2 ( or Aviation High tack sealant) on the threads and put oil under the head of the bolt.
Hope this helps
Al
