I close to giving up and taking my car to the shop. I just finished installing new head gaskets and the car is still running to hot. I checked the aluminum heads and block deck for flatness and saw no issues. I torque the heads down per instruction from trick flow. I back my timing down a bit and saw no benefit. I post before what I have for a cooling system, but I'll post it again. A summit univ alum radiator, flow kooler alum high flow water pump, mach pulley system ( standard drive), derale electric fan w/ rich 66 shroud setup, stewart 180 thermostat w/ bleed holes, high pressure 27 lb radiator cap, I put in prestone 50/50. I also tried removing the shroud and putting the fan back on the radiator but saw no difference. I have run through what limited knowlegde I have and cant figure this out. Any other ideas I may have missed here?? thanks
Len
Len
