well to start off this is where i get stuck, i have 4 wires that must be tied into an ignition hot terminal
1) two wires from my aftermarket BECOOL DUAL FANS
2) one wire from my tachometer
3) and one wire from my gauge pod
hope thats enough info, my question is can i tie all four wires into that one ignition terminal on the fuse panel or will i blow the fuses,
and where else can i tie a wire that needs to be hooked to an ignition (key in the on position) source, thanks all info is appreciated i really need some help with this step
