torque specs on bearing kit
Hi the torque specs are 12 ft lbs This is from the chevy 2 kit ...i'm sure it's the same kit let me know if you feel a difference i'm thinking of doing it also. Oh yeah when you tighten the bolts be sure the grease fitting is positioned correctly and when you torque the bolts do it when the wheel/pitman arm is straight sometimes you'll get a pull or hard time with the wheel returning Good luck Neil63ss
