Well it seems as if something is wrong with the two 9776 450's we have on our tunnel ram. I was just messing with the idle mixture screws to try and lean out the idle mixture a bit and turning the screws makes absolutely no difference what so ever. Idle does not go up when leaned out and does not go down when made richer. Car is idling at 1000.
Also one side of the engine is richer than the other. You can rev it up and it clears out then starts loading up after a couple seconds on the drivers side. I currently have all 4 idle screws at 1 1/2 turns out. I turned them all the way in and it made no difference. I did not think it would run with the screws all the way in?
Does it sound like junk in the idle circuit or something else? The carbs sat for almost 4 years on the engine they were on. I am thinking about getting 2 kits and rebuilding them.
Anybody have any ideas?
