1 - 15 of 15 Posts
column
ill have to call ididit tomorrow then because if you butt the steering column shaft flush with the steering box shaft the shifter linkage hits the firewall
this is a column shift column. any one have a picture?
Discussion Starter · #9 ·
first of all they send all column shifts out with a straight lever which hits the firewall. then i had to shim the column mount down so it wouldnt hit the dash
and trim a inch off the mount. today they sent a dog leg for the lever which works fine now. they shouldnt call it retrofit if you have to shim and cut
Discussion Starter · #11 ·
Do you know if that is how they send all of them out or was it possible that the wrong arm was installed?
the tech guy said they were sending them out like that. it had him confused:rolleyes:it is a really nice column but its frustrating when
things like this happen.i told them about having to shim the column down
and cutting the mount off and he said he didnt know what to tell me. and also the plastic collar that covers the mount will have to be cut and modified. this doesnt sound like a retrofit to me
Vendor
and Im about to purchase one of those for my 66. I wonder if they have the same issue. Even though the lower mount is different.
Is your column a floor shift or a column shift. The issue is with the column shift model? All the floor shift models that we have installed have been a perfect fit.
Discussion Starter · #15 ·
its a column shift. ive looked at the foor shift and it is different. the shifter colar hit the dash without shims and cutting the mount. maybe i got one that was made on monday. i dont know but ididit didnt have any answers for me.so i made it work. when i asked had they had any complaints the rep said not that he knew but most people just make it work:confused:
1 - 15 of 15 Posts
