R84015-3 | 4011 | 800 |
These carbs were aftermarket only for street use. I think they were meant to compete with the reintroduced Carter AFB.Sure does look like that carb was over-stamped... Like someone was trying to use it for a numbers-matching installation. Look closely and you can see artifact stamps beneath the more prevalent newer stampings... Its' highly suspect...
Regardless, the overstamping of dissimilar numbers/letters is perplexing... no?!?These carbs were aftermarket only for street use. I think they were meant to compete with the reintroduced Carter AFB.
Better than a Zenith or Stromberg.. LOLI do believe its a 4011 800cfm after doing more research. Spread bore, manual choke and the gaskets look correct. Apparently it was on a built 454 so the 800cfm makes sense
Are these any good?
