1 - 13 of 13 Posts
Getting Ideas for my 66 Four door. I was thinking going classic with Cragar SS wheels, low profile tires, summit has some that around 140 a pop. What is a good combo without modifying any original body panels? I don't want to go too homey, more classic.
What is the largest wheel that I could fit in there?
Any other suggestions on wheels?
I went with American Racing Chrome ralley's, 14x7's, they do make them in 15 inch also. The 14's were less than $80 each, and you can change the center caps later on if you desire.
Aren't tires for those size wheels more expensive than 17's?
I would go with a set of 17 x 8's! Maybe some AR Torque Thrust M's if you want to go classic but update it a little. You should be able to fit those no problem, especially since you're going with a lower profile tire. I would go with a 245/40/17 all around.
John
Aren't tires for those size wheels more expensive than 17's?John
Nope, a good brand will run you about $100 per tire. I'm going to be needing to buy some 16 inch tires here soon for the Chevelle. Those are a little harder to come by, and probably cost as much as 17's.
Hey Ben I have 14X8 with 4.75BS P215/70 R14 on mine...
Discussion Starter · #11 ·
What year chevelle do you have sgt?
I have drum brakes all around, so I don't want to see too much behind there.
Brake paint of choice anyone?
I have a 72 Chevelle Malibu currently a work in progress.
My 66 4 dr Nova had drums all around also, but swapped the front drums for a pwr disc brake conversion. Might be something to look into..one of the best upgrades I've done.
Discussion Starter · #13 ·
My parents have a 70 chevelle (no malibu trim, 307) and we are getting ready to start on another 70 Malibu, gonna be a 396. It was my uncles who passed away. Needs a frame off, and a lot of work.
How far are you on your 72?
PS I will eventually upgrade the front brakes, but right now i need to get her in shape for my wedding this fall :)
1 - 13 of 13 Posts
