Last week I went to the track for the first time and had a pretty good day. Didn't do any tuning, just got used to the car and track. Everything worked pretty good but of course I have to believe there's more in it. At least no glaring problems to fix.
So this weekend I'd like to see if I can get a little more out of it. How's this sound for a plan?
1. Make first run with everything the same to establish baseline. Stop on return road and check plug just to see which way to go when I get to jetting. I think it's pretty close based on being fairly clean and consistent the first time out, just not perfect.
2. Second pass, change from 4 hole spacer to open spacer. I figure this is a good place to start. Either it works or it doesn't. Go with the best the rest of the day.
3. It's currently locked out at 38 degrees. Try 36, if it improves, try 34, if not, try 40 and so on until I have a clear optimum setting.
4. Jetting, up or down depending. Do I change front and back together or just one or the other?
Does this sound like a reasonable plan or am I all wrong? Here's a link to my thread about the first time with times and setup if you're interested.
Any constructive advice will be much appreciated!! Thanks in advance, Mike
http://www.stevesnovasite.com/forums/showthread.php?t=116430
