1 - 20 of 21 Posts
1967 2 Door
Bought new rubber for my vent windows but having a bitchin time installing it. Hard to press the rubber into the channel. I’m using plastic tools to press them in from the edges but no luck. Trued using soapy water and even tried using cable ties to hold them in place while pushing the rubber in. No luck. Any suggestions?
Thanks,
Rob
I haven't done this but I wonder if microwaving the rubber for a short time might soften it up. Try some of the old rubber first!!!
I haven't had to do this either, however in the tire world, linseed soap works awesome to lubricate tires when mounting on wheels. I have used it in other applications where rubber needs to be lubed to fit as well. It is non-corrosive and washes off when finished.
Installing the rubber is the easy part.
Getting the glass positioned properly in the frames with the new rubber seals so they align properly when closed is even more challenging.
I take a bottle of dish soap and douse the rubber with dish soap. Load it on and smear it all over with your hands! Then I do the same to the metal frame. Then I give them both a light rinse leaving most of the soap on them and then rinse my hands so I can get a grip on everything.
After that you have several minutes to get the rubber in the metal channel correctly. You can even screw-up a couple times and remove the rubber and re-install it until you get it perfect.
The first time I did it was a little challenging but after that it has been pretty-easy. You have to force it into the corner first. Then do the rest.
Afterwards rinse the heck out of the assembly to get the soap out
1967 2 Door
Discussion Starter · #9 ·
Thanks all. I got them in with help from all your posts. I put them in some hot water for a little while then I put some assembly lube on the rubber and started with the corner. Then I used the plastic trim tools to push in the sides a little at a time. It was easier but not easy!
Rob
Rob
You have to hope it wont distort the rubbers. Certain greases will do that.
Thanks,
Rob
I have done several of those and the best thing I’ve found is boiling hag water and spray silicone lubricant but they stil a pain in the rectum
I still have my OG's that why i never replaced them nothing ever seems as good as the OG's a little dry rot isnt a big deal the car never in the rain my windshield rubber is also OG
I installed the reproduction seals but could not get the vent window to close. I eventually pulled it back apart and reinstalled one of the original vertical seals and the window closes fine now. Im
Glad that original seal was still in good condition.
i'm pretty sure i have the original wing vent rubber seals in my 66. they look decent an seal well. wind shield rubber though is new, but original glass.
I agree 100% I have tack welded the frames to get the rigidness back. Also I don’t want a car that’s had the 1/4 panels replaced. I don’t give a damn who does them the car is never like it was from the jump, the aftermarket parts never fit like the OG. Just my opinion. BTW I have passed on a few cars that didn’t have the serial number on the 1/4 panels. I would much rather have a properly installed patch panel.
I spent 4 hours today on my '72 today installing repop rubber on 1 wing window. After the fight I ended up with obvious gaps. The window moved ok but the seal is very poor, sending them back. I will be putting the originals back in.
Get some made by precision or Metro they in my opinion are the best
1 - 20 of 21 Posts
