does anyone happen to know what the dwell needs to be set at for the points on a 70 nova with a 307??? thanks!
I agree 100 percent. I ran points for a Loooong time in my 76 nova and always 30* then set the timing. After that as long as the points are at 30* the timing should be correct.IgnitionMan said:30, NOT 28, NOT 32, NOT 287, not 17...30.
Set the dwell first, then the timing, while making sure the dwell stays steady. After 1,000 miles, reset the dwell...to 30 degrees...because the rubbing block on the points wears into the points cam. Timing should come right back when the dwell is returned to 30 degrees.
It would back fire through the glove box occasionally!novaken said:What would happen if you set it to 30 1/2?
I hate it when that happensDrDenny's 69 Rat said:It would back fire through the glove box occasionally!
that and its been known to cause passenger seat stains tooDrDenny's 69 Rat said:It can make for a bad hair day for the passenger.![]()
