March 17, 2023
I should know by now to not let @Stroker Ace Ventura be my voice of reason. I ordered the seats for the Nova.
"The Plan (revision number 98743927)" is:
+Get car up onto cribs & measure for driveshaft and order driveshaft...this really should have been the priority.
+Finish last years business - finish mounting up rear shocks, plumb brakelines, hook up e-brake cable, don't forget about the drivers side front wheel bearing cap weirdness, install grease fittings and grease everything, don't forget to drain some gear oil out of the rear because I overfilled it.
+Get driveshaft and install
+Get the welding done. I can probably drive it to some place to have it done.
+New business is going to be these seats, rebuild the steering column, procure a shifter and reverse valve body for the TH-350 (this is so that I can install the floor shifter I want that will be compatible with the TH-400 later).
