May 5, 2022
I have some photos but I’m not going to post anything up at this point, nothing too exciting happening. Weather is good and I’ve finally begun
Overhaul Rear Suspension and Rear
So, I plan where to put my jackstands. Jack her up and get her on stands and remove the driveshaft. Yes I used tape on the U-joints. No I didn’t plug the transmission tail shaft YES I have a huge puddle of transmission fluid I’m looking forward to cleaning up.
Step two is eyeball everything else. Ohhhh crap, E-brake cables. Ohhh crap I didn’t take the wheels off as I had some silly plan / idea that i could disconnect everything and wheel the entire rear out from under the car. E-brake and try to get the wheels off…drivers side worked, passenger side not so much. Dropped her back on the ground and jacked up my shop light in the process…not good but it still works it’s just worse for wear.
Loosen the lugs and she’s back in the air on the stands and it’s time to remove the drums. Passenger side comes off fine but drivers side isn’t playing nice and the knock outs on the rear backing plate are non existent so I’m not backing the shoes off that way…Lots of hammering, turning, hammering and jiggling and it’s off.
Now it’s time to strip off the brake drums…blah. It would have been really slick to keep everything together just in case but whatever…the right tools for this job would have been helpful also but a pair of lineman’s pliers worked pretty well too.
Tons of dorking around with the stupid e brake cable retaining blah blah blah but they are off and I got off work about 2 hours and 20 minutes ago.
What’s left? Brake line, shocks and then…what is the best approach from there? many people spoke of undoing the front mount from the pocket with those three bolts but after doing that I’m going to need to still get the leaf off of that mount to reuse it right?
Oh also…i lied i’m going to post one photo
LOL passenger rear shock has a bolt just dangling out there. Epical!
