I had a Hurst 1/4 stick reverse pattern T-350 or powerglide shifter. It works on either a forward or reverse pattern T-350 it just has a tendency to jump past second gear when you shift from low to second. It works great other than that; nothing like a 1 to 3 shift at 6000 rpm to spoil a pass on the strip. The gate is designed to let you go from 1-2-3 by using the squeeze handle and pulling rearward. The other way the gate lets you go from 1-3 with only a slight push on the handle. People told me I couldn't shift and I was pressing to hard and it didn't have to be shoved to make it move. The fact is it's the wrong style shifter for a forward pattern transmission. BUT IT WILL MAKE IT SHIFT!
THE GATE IS WELDED IN AND ISN"T REMOVABLE AND CAN"T BE SWAPPED.
