1 - 2 of 2 Posts
Are the hubs and spindle for a drum brake 66-67 the same as a drum hub and spindle for a 68-69 model. can you use the 66 or 67 hub on the 68-69 spindle.
Hubs are the same, and the main difference in the spindles is the size of the lower ball joint taper. Also, some real early spindles have 7/16 steering arm hole, later ones are 1/2, I believe.
Jeff
1 - 2 of 2 Posts
