I have a crankshaft out of a 400 small block, and I wanted to know if it's cast or steel. How do you tell the difference? ...If it's steel I'm building a 383...
tap on the counter weight with the shank of a screwdriver...if it sounds like your tapping a brick then the crank is cast...if it rings when you tap on it...its a steel crank;)
