I just took my rod and straightened it til it fit an worked. You also make your own by using some small round bar stock.how do I make my heat riser thinga-ma-jigg work with my Q-Jet? I doesn't reach as you can see in the pic. Can I buy an extended arm for it? or do I have to make one?
that's what I thought. I guess it's off to the hardware storeI just took my rod and straightened it til it fit an worked. You also make your own by using some small round bar stock.
What he said!I just took my rod and straightened it til it worked...
sounds like a lot of work.The company I work for makes computer controlled 3D structural wire bending machinery. I can probably get you a deal on one if you're interested.
You know I wondered if a coat hanger would work.Remove the cover from the Choke Thermostat, romev the current chioke rod. Make new rod from a coat hanger wire (thats what I use) Make sure you copy the bends at choke stat & carb. So it will attach like the factory rod, the cover holds the rod in.
I make my new rod with a middle bend. This allows you to make rod shorter or longer by making the bend more or less. As you measure for new rod, make sure you have the carb gasket and carb bolted down.
Good luck
AL
