adjust your
brakes just a tad loser , at least make sure they're not dragging.
Caterpillar makes some 50 gear oil i'm gonna use this time. I used it in the transmissions of my trucks ( tractor trailers, thought it might do better than synthetic and it did but gained some temp back after a month of heavy use ). I serviced Cat equipment on a surface mine , 50 weight is what goes in the final drive planetarys of D 11 dozers. So if it will stand that ,, it oughta be good for one pass in the 1/4 at a time i'd say.
what kind of air filter are you using ??
exhaust ?
i'd adjust the valves ( assuming its hyd ) where the lash is just out of them and get poly locks to keep them there.
put a ford solenoid on the positive cable coming from the battery , wire it up so you can disconnet the batteries load from the alternater just before you make the pass.
could get an underdrive pulley for the crank to spin the water pump slower while your at the track , could keep both pulleys with ya and both belts needed
get a distributor curve kit and see if bringing the timing in quicker , or slower , might help ur mph
really depends how bad you want that extra MPH
get some of this
http://www.jegs.com/i/Pro+Blend/797/6080/10002/-1
and mix with the wheel bearing grease for the front wheels.
put 2oz on this
http://www.jegs.com/i/Pro+Blend/797/6074/10002/-1
in ur rear gear oil
disconnect the vacume line going to ur trans modulator and plug the carb side ,, it should shift harder,, or u could install a shift kit in the transmission
