My pistons goes a little bit beyond the deck height at TDC. This varies a little, some pistons ends 0.003 inch above top deck, others as much as 0.009 inch.
If the piston-to-valve clearance is within spec., I guess this is not a problem?!
Now I wonder how thick head gasket I need for compensate for this? In compressed mode, of course.
The engine will see no more than 6100 rpm, and I'm using hypereutectic piston. The piston-to-cylinder-wall clearance is tight but within spec.
Advices are very welcome!
Kind regards /Peter
Kind regards /Peter
